Year: 1989
Make: ford
Model: e-150 econoline
Engine Size: 302
I HAVE TO REPLACE THE SWITCH ON THE ACCUMULATOR AND HAVE TO VACUUM DOWN THE SYSTEM. HOW IS THIS DONE AND WHAT HOSES DO I HOOK UP?
billy
Hook up your manifold gauges to the system and pull your vacuum thru the yellow hose.. If you don't have a micron gauge, just pull it till it reaches 29.9 HG at sea level, you'll lose one HG of vacuum for every 1000 feet above sea level, make sure the vacuum holds, then charge "INTO" the vacuum.
I HAVE DUAL AIR HOW MANY OUNCES OF OIL SHOULD I PUT IN?
billy
