Year: 2002
Make: Chevy
Model: Cav Z24
Engine Size: 2.4
Ok, so as u can see, i'm baffeled over my ac....I can hear the pump kick on and run....i ran a leak test...it holds freon...the lines even get cold!! but the only air that comes out of my vents is hot air!!! wtf!! even when my car is at normal running temp...only warm air comes out my vents....but the ac lines r ice cold....any help?!?!? PLEASE
If the suction line is ICE COLD, check for a blend door problrm, what was done to the car before it began blowing hot air? any work under the dash? Or hood?
Blend door,you probably lost vacuum that runs the puller motor,had that problem on my '00 sunfire.
No temp door I know of uses vacuum- either cable or electric actuator-- look for loose cable- or bad actuator- take either loose- move temp door by hand.....see if it shuts off at either full cold and full hot....
