Year: 2003
Make: Chrysler
Model: PT Cuiser
Engine Size: 2.4
Refrigerant Type: 134A
Ambient Temp: 80
Pressure Low: 40
Pressure High: 50
MY relief valve has started popping off, pressures are 40 low / 50 high at idle with clutch running. Pressures were taken from the ports that are side by side on right side top of engine compartment. Pressures fluctuate when the condenser fan kicks on. I also see what looks like a high side port down by the compressor, between compressor and condenser (my arms are to fat to get the hose connected down there.)
Seemed like compressor was the problem, so I changed compressor, receiver dryer, liquid line w/ orifice tube, flushed evap condenser and lines.
Pulled a vac, charged it. And.........I still have the same problem, same pressure readings, relief valve popping off.
Any suggestions??
Do I need to get someone with skinny arms to use the other port for correct pressure readings?
Row Z
Row Z
You're using the wrong port. If you get connected to the other one you'll probably see 350 or more psi.
Assuming it's not overcharged, it sounds like a fan control problem. The fans should run constant while the car is sitting still with the compressor engaged in hot weather. Probably there is a sensor on the high side that tells the ECM the pressure, then the ECM turns the fans on. If that sensor is bad, the ECM also won't be aware of extremely high pressure. It is supposed to turn the compressor off before the relief valve pops.
There is a sensor on the end of the compressor, I'll check it out tonight. Thanks, for the help.
Row Z
Dealer tells me the sensor on the end of compressor is the High pressure cut out switch.
Row Z
Check out this post from almost a year ago and it may shed some light on your pressue readings..Hope this helps.
Hooked up to the hidden service port at the compressor, pressures are good. Changed out the low speed fan relay, and now the fan kicks in when clutch is on. Problem solved.
Looks like a $10 relay was the problem. To bad I blew all that money on Compressor,etc,etc,etc.
Oh well...live and learn.....the wife is happy now that her beloved PT Cruiser has cold AC again.
Anyone have suggestions on a good economically priced vacuum pump? suitable for a DIY'er?
Thanks for the help.
Row Z
check out these Mastercool vaccum pumps there is one for every price range..
R12 and R134a systems must be vacuumed before being charged if they are opened. R134a is even more particular about air in the system than an r12 system. A little bit of air will skew the pressures.
Ah, my favorite magic in a can...
"Clown be Gone!"
B.
Well I missed his return, and can only gather he did not heed the warning, as the clown be gone. Thanks for taking care of that B.
