What is needed to vacuum system prior to refilling
rjdevita on Wed September 21, 2005 12:08 PM User is offline
I have a GAST DOA-V110-AB vacuum pump. Can I use it ? If so, how do I connect it, and what prevents contaminants from entering the pump ?
clueless on Wed September 21, 2005 2:20 PM User is offline
From the manufactures brocure in pdf.
Oilless Diaphragm Vacuum Pumps and Compressors (built before 6/02)
OPERATION & MAINTENANCE MANUAL
Product Use Criteria:
• Pump only clean, dry air.
• Operate at 40ºF - 104ºF (4.4ºC - 40ºC).
• Protect unit from dirt & moisture.
• Do not pump flammable or explosive gases or
use in an atmosphere that contains such gases.
• Corrosive gases and particulate material will damage unit. Water vapor, oil-based contaminants or other liquids must be filtered out.
• Protect all surrounding items from exhaust air. This
exhaust air can become very hot.
• Consult your Gast Distributor/Representative
before using at high altitudes.
Sounds like it is not for this kind of work. It will do the job but it will not have a long life.
For a fitting see if tim can get you a ROB-15495 adapter. There are others would need to know what thread is on the pump intake fitting.
Edited: Wed September 21, 2005 at 2:21 PM by clueless
rjdevita on Thu September 22, 2005 8:14 AM User is offline
thanks for the info ! I should have thought to check with GAST.
mk378 on Fri September 06, 2013 5:56 PM User is offline
That pump will not develop sufficent vacuum. You want to get as much air out as practical, which means an oiled rotary pump.
wptski on Fri September 06, 2013 6:54 PM User is offline
What's with the date on that post, 8/22/2005???? Why did it go to the top????
TRB on Fri September 06, 2013 6:58 PM User is offlineView users profile
Because MK378 posted to it after all these years.
wptski on Fri September 06, 2013 9:54 PM User is offline
Nope! That thread/post of 8/22/2005 was at the top of the list earlier. I wondered how/why it was there and then mk378 replied to it. Go figure......
TRB on Fri September 06, 2013 9:59 PM User is offlineView users profile
Just looked at the moderator logs. I Spam post was deleted.
mk378 on Fri September 06, 2013 10:10 PM User is offline
Something about your forum software. Sometimes.Zombies.Will.Rise.
TRB on Fri September 06, 2013 10:39 PM User is offlineView users profile
Mod deleted a spam post., which is why the thread looked like it was updated.
wptski on Sat September 07, 2013 9:24 AM User is offline
What happened now(9/7/13 9:23am EST), top of the forum, every section's last post by is blank except this one?
Edited: Sat September 07, 2013 at 9:24 AM by wptski
TRB on Sat September 07, 2013 9:30 AM User is offlineView users profile
I reset things last night. As soon as someone posts to a thread the name will show up. Notice mine next to Nick's post now.
