04 gto air compressor
Posted: Fri Jul 28, 2017 2:37 pm
by mj skins
The compressor clutch in gages when the engine is cold and will work until you shut the car off, but the clutch won't work after the engine is warmed up. I don't know if it's a sensor or what.
Re: 04 gto air compressor
Posted: Fri Jul 28, 2017 3:23 pm
by Dougflas
Try using a screwdriver handle and tap the clutch plate. See if it engages. If so, you have the well known gap problem.
