Evaporator Temp Sensor
tpntx
Post by tpntx »
My 2010 Chevy Pickup has a bad sensor telling the system it's 32d. So the compressor short cycles. I know I have to pull the dash to get to the sensor which is a project for another day.
Right now in DFW is upper 90's and it will only get hotter through August.
So I know I can jumper the relay socket to where it's always on. Is there a chance it will freeze up in this heat or am I fairly save until it starts to cool off. Im going to fix it but I'd rather not deal with it at this time.
Thx
Re: Evaporator Temp Sensor
I'd be more afraid of high pressure- when you jumper the relay, you have no control- if head pressure should rise to over 400 psi- the system cannot shut off compressor and you chance blowing out the high pressure relief valve- if really hot out- there needs to be an electrical cut-out which you will be bypassing.. A compressor running continuously under low load will destroy itself due to lack of lube due to low oil flow back to compressor- so if you want to still chance it- make sure head pressure stays below 400 and suction stays above 21 or so....not sure if you can watch those pressures while driving though.
