2012 GMC Yukon AC + chiller mess
Posted: Wed Aug 25, 2021 1:00 pm
Whats going on guys sorry for the novel,
I've got some problems, havent had much luck finding anyone that knows anything more than "put in it what the sticker says":
I will do my best to describe but most likely you'll need some more info ive forgot/overlooked/dont know
truck came with orifice tube for front ac, TVX for rear and an accumulator. I have gutted the rear AC, moved and replaced the accumulator with a different one, and added a chiller set up for an air to water intercooler that also uses a TVX.
what is there now:
out of the compressor the high side hose has a small sealed drier(I think?) and a pressure sensor on it (stock) to the condenser (stock). right off the condenser i have installed a Tee fitting and split the high pressure line;
side 1 goes to a filter drier and then to the TXV on the chiller. low side line returns to Tee right at compressor inlet.
side 2 hits a solenoid to cut off refrigerant going to the cab, high side service port, thru a universal orifice tube & housing, to the cabin evaporator, then to an accumulator(r12 with 134a port adapter - it was set up for -10 o-ring fittings already) with low side service port and back to the previously mentioned Tee at the compressor.
I have messed with the charge of the system from one end to the other, slowly filling from undercharged.
strictly filling with gauges leads to poor performance out of both the evap and chiller - however my service ports are only on the orifice tube side, i can read pressure directly after the compressor thru hptuners (and also command compressor to run) so im not real sure whats going on with the chiller
the best performance out of both systems leads to it being way over charged. IE charging it for lowest temps out of both systems. if the system is running i can continue to charge and get vent temps down in the low 40s (90* ambient) and chiller water temps near freezing. however after it sits and is started back up the compressor shuts off on high pressure 400psi+.
I guess what i am trying to find out is if this system is EVER going to work, is there some fatal flaw i should address > should i put a TVX on the cabin system and delete the low side accumulator? most of the GM fittings have been adapted to O-ring fittings i used -8 barrier hose for most of the high side, i dont know if dropping it down to -6 would make a difference? or I could swap most of it to hard lines? the low side is mostly -12 hose with -10 fittings.
i dont know if the accumulator and drier are just cycling refrigerant between them or what. but it seems that its never been consistent - unless ive left them both performing poorly.
what is there now:
