R4 compressor, very low on refrigerant.
You have a leak. Find & fix the leak first.
Jumping Pressure Switch
- bohica2xo
Re: Jumping Pressure Switch
Thanks! First step is to find the leak(s).
What r12 can tap would you recommend when refilling?
Is Sercon RJ12 ok to refill my system?
Is it the same as plain R12?
Thanks!
Thanks!
