Adding/draining oil from a Ford FS10 compressor
mcconnell
Post by mcconnell »
I guess the subject line says it all. How do I add/drain oil from a Ford FS10 compressor. There is no plugged port on the case.
Thank you
Dougflas
Re: Adding/draining oil from a Ford FS10 compressor
Post by Dougflas »
To drain it, remove it from vehicle and turn it up side down. You should rotate the shaft by hand also. To fill it, pour oil into suction port and also turn shaft.
