Testing TXV's
Testing TXV's
Postby Dougflas » Sat Jul 16, 2016 6:06 pm
greenquark
Re: Testing TXV's
Postby greenquark » Sun Jul 17, 2016 1:45 pm
Question: Must the test be with compressed aire only? Or it must have the same output with any source of air? Let say : With a small pump, or even bow it with the mouth?
Re: Testing TXV's
Postby Dougflas » Mon Jul 18, 2016 6:02 am
this test is with the system being under a condition of charged. Make sure vehicle has run for 10 minutes or so the stabilize the refrigerant syatem.
greenquark
Re: Testing TXV's
Postby greenquark » Mon Jul 18, 2016 11:33 am
Dougflas wrote:this test is with the system being under a condition of charged. Make sure vehicle has run for 10 minutes or so the stabilize the refrigerant syatem.
Huh? The pdf does not describe that. I am referring to the right angle Tvx. It says remove the Tvx.
Re: Testing TXV's
Postby Dougflas » Mon Jul 18, 2016 12:18 pm
And I was referring to the on vehicle test. Yes, you can use dry shop air.
Return to “Automotive Air Conditioning Procedures, Tips and FAQ.”
