73 stingray with high AC pressure
Cgregerson
Postby Cgregerson » Mon Feb 19, 2018 9:05 pm
I have a 73 stingray and just replaced the condenser, VIR, and compressor with all new parts. Charged the system with R134 and the pressures are running very high around 400 for the high side and low pressure is running around 50. Any ideas of what may be causing this high pressure?
Re: 73 stingray with high AC pressure
Postby Tim » Mon Feb 19, 2018 10:03 pm
Poor condenser performance.
P:602-233-0090
Cgregerson
Postby Cgregerson » Tue Feb 20, 2018 8:38 am
Tim wrote:Poor condenser performance.
Can you explain, what would cause the poor performance.
Postby Tim » Tue Feb 20, 2018 9:13 am
Tube & Fin condensers will not handle the heat load of R134a refrigerant. An upgrade to a parallel flow condenser will help. Finding a direct drop for your vehicle will be difficult.
P:602-233-0090
Postby bohica2xo » Thu Feb 22, 2018 8:44 am
Converting a Corvette to 134a is a fools errand.
R12 is still available. Some cars just need to stay that way, and the Corvette is the best example.
Postby Tim » Thu Feb 22, 2018 9:04 am
bohica2xo wrote:Converting a Corvette to 134a is a fools errand.
Amen.
P:602-233-0090
Postby Dougflas » Thu Feb 22, 2018 6:18 pm
The above is exactly correct. Spray a water hose on your condenser. If all pressures drop, you have proven what was said. Use R12 and be done with it.
