R134 added to R12 system
Posted: Thu Sep 07, 2017 5:53 pm
by GREMLIN
Ladies, Gentlemen, Have a situation. Was having some work done on a 90 1.6L 220k mi. Mazda & Tech says very little R12 escaped while he was working on a coolant line. Says he took the protective cap off to get at a coolant line, and hit the Schrader valve a couple times. A/C worked fine prior to the shop work. I understand the shop charged the system with R134. Worked very well for two days then zilch. Pressure tested with nitrogen, found a leak in the condenser. Gonna have a new condenser, dryer, & R12 installed/charged. Tech did not mention a flush for the 134, nor changing the oil in the compressor. Should I be concerned about the compressor oil & system flush?? I understand our local NAPA has R12 for sale to a certified tech, and I'd like to stay with R12 unless there is a reason not to. Thanks in advance for any thoughts.
Re: R134 added to R12 system
Posted: Fri Sep 08, 2017 5:46 am
1. Very "coincidental" that AC worked fine before such repair and now you have a condenser leak.
2. I thought a tech would know that it was not good to add R134a to an R-12 system, and if a tech converts to R134a that there needs to be a sticker stating that. Did tech actually add R134a through R-12 shrader valves on your Mazda, or did he add R134a Acme adapters?
Posted: Fri Sep 08, 2017 3:12 pm
by GREMLIN
Through the Schrader Valve. No adapters. Said it would be fine.
Posted: Sat Sep 09, 2017 6:54 am
GREMLIN wrote:Ladies, Gentlemen, Have a situation. Was having some work done on a 90 1.6L 220k mi. Mazda & Tech says very little R12 escaped while he was working on a coolant line. Says he took the protective cap off to get at a coolant line, and hit the Schrader valve a couple times. A/C worked fine prior to the shop work. I understand the shop charged the system with R134. Worked very well for two days then zilch. Pressure tested with nitrogen, found a leak in the condenser. Gonna have a new condenser, dryer, & R12 installed/charged. Tech did not mention a flush for the 134, nor changing the oil in the compressor. Should I be concerned about the compressor oil & system flush?? I understand our local NAPA has R12 for sale to a certified tech, and I'd like to stay with R12 unless there is a reason not to. Thanks in advance for any thoughts.
GREMLIN wrote:Through the Schrader Valve. No adapters. Said it would be fine.
I don't like any of this, smells very fishy, if he added R134a (unknown amount), did not flush out oil or add compatible oil, added through the R-12 shraeder valve, and condenser suddenly got a hole, So I think the tech bypassed EPA or similar regulations, as well as AC sense. I would replace what you suggested, and stay R-12. Good luck.
I still run R-12 in my '88 Mazda truck.
Posted: Sat Sep 09, 2017 12:53 pm
Is the system working now?
You've mixed refrigerants. So if working, don;t mess with it and wait until it fails. Then clean system and go back to R12.
Posted: Mon Sep 11, 2017 9:49 pm
by GREMLIN
Tim wrote:Is the system working now?
No not working now. Worked two days real good then nothing. Compressor does not engage unless the pressure switch is shorted/ jumped.
This guy was not the first tech to tell me they just add R134. I'd like to find a tech in the Colorado Springs, Co area that could flush & charge the system with R12.
Posted: Tue Sep 12, 2017 1:58 am
by GREMLIN
Exactly why I'm looking for Looking for someone in the Colorado Springs area that does automotive AC correctly. I've heard "Just add R134" more than once.
Posted: Tue Sep 12, 2017 6:08 am
Shorted the pressure switch and compressor engages? And you had leakage? I think that you still have a leak.
My guess is that some shop in Colorado Springs area will be able to do R-12 - the refrigerant must match your refrigerant oil - call independent shops, see if there's a real AC shop around, even try Denver if necessary.
Check with classic car clubs nad see what they do, and I know in Phoenix area that my own mechanic's independent shop still does R-12, as does the local radio show mechanic's shop.
Posted: Wed Sep 13, 2017 1:16 pm
by GREMLIN
Cusser wrote:Shorted the pressure switch and compressor engages? And you had leakage? I think that you still have a leak.
Original Post: Pressure tested with nitrogen, found a leak in the condenser. Gonna have a new condenser, dryer, & R12 installed/charged. Tech did not mention a flush for the 134, nor changing the oil in the compressor. Should I be concerned about the compressor oil & a system flush??
