A slightly differnt A/C system
ice-n-tropics
Re: A slightly differnt A/C system
Postby ice-n-tropics » Mon Sep 11, 2017 1:25 pm
Thinking about air cooled ventilated rotors or solid CO2 to cool multiple dry clutch stack using disk break type rotors
AdmissionPro456
Postby AdmissionPro456 » Fri Oct 27, 2017 3:42 am
The split air conditioner comprises of two parts: the outdoor unit and the indoor unit. The outdoor unit, fitted outside the room, houses components like the compressor, condenser and expansion valve. The indoor unit comprises the evaporator or cooling coil and the cooling fan. For this unit you don’t have to make any slot in the wall of the room. Further, present day split units have aesthetic appeal and do not take up as much space as a window unit. A split air conditioner can be used to cool one or two rooms.
