For green O-rings and the metal and Green seal material on compressor gaskets.
For installation should I use PAG or Super silicone grease (by super lube).
Silicone grease probably help keep in place and does not dry out.
Thank you
Green O-rings/seals
Re: Green O-rings/seals
Nylog is what you should use. Available from the site sponsor:
http://www.ackits.com/nylog-lube-blue-l ... arch=nylog
Nylog Blue is compatible with the refrigerant and seal materials.
