'93 Silverado c1500 AC replacement
7echo
Post by 7echo »
I got an old '93 Silverado single cab project truck for my son and I and I to work on, teaching him some repair and PM stuff. The old R4 compressor was shot so I am looking into options for replacement.
I need some comments and opinions on my plan-
Install new compressor, accumulator, condenser, hoses, etc. Most everything but the evaporator. I want to use R134 refrigerant.
I am thinking to use a Sanden FLX7 #4864 compressor. They have several manifold options for the hose connection, which one do I need?
http://www.sanden.com/flx7.html
I can buy or fab brackets. I will have new hoses made(probably at a Parker store, what do i need to know before talking to them?).
I think I need a parallel flow condenser. I am trying to track one down that is close to the OEM dimensions and fittings. Overall it is 30 1/4" wide, 16 9/16" high, and 1 1/2" thick.
Any help is appreciated, including telling me my plan is a bad one, just please give me some options ; )
Thanks.
Re: '93 Silverado c1500 AC replacement
Anything is better than an R4 compressor, but these seemed to be "better" in a single cab truck than in a dual-AC system.
71403
Post by 71403 »
Have installed a few of the off-brand replacements that are PF in spec and appearance. Haven't had a bad one yet to cut open and verify true PF. Quality is questionable - sent back two that came with metal chips in the discharge line.
There is a AC-Delco parallel flow condenser for these trucks it's labeled "for R134A retrofit". Well, at least the picture _looks_ like a PF... haven't had hands on one yet. Hopefully better quality than the off-brand.
Check the recirc door is functional. I see a lot of these trucks with bad actuators and/or broken shafts from hack job replacements.
7echo
Post by 7echo »
"Check the recirc door is functional. I see a lot of these trucks with bad actuators and/or broken shafts from hack job replacements."
Yes, that one was bad. I have set it in the re-circ position til I feel like digging under the dash to replace the motor. I found a write up on line. I run all my cars AC in re-circ probably 95 percent of the time.
7echo wrote:"Check the recirc door is functional. I see a lot of these trucks with bad actuators and/or broken shafts from hack job replacements."
I had to grind down both ends of a 5.5mm socket to get that %^&*$@%&@#%& thing out of my 2005 GMC, the hump is in the way !!! So was still a pain !!! I used a Dorman aftermarket unit after disconnecting the harness (while in the AC position) for a year.
