AC Clutch Coil Diode
arty4444
Postby arty4444 » Thu Jun 08, 2017 7:40 am
I just bought a new clutch kit for an older vehicle. The original service manual indicates a Zener diode between the coil leads to deal with voltage back flow. I haven't pulled my original coil yet but I find no visible diode on my new coil. Could the diode be out of sight under the wrapping with the coil windings (I feel no "lump") or elsewhere in the wiring harness? Or should I add my own if not sure?
Thanks in advance.
Re: AC Clutch Coil Diode
Postby Dougflas » Thu Jun 08, 2017 12:13 pm
I have seen diodes mounted on the connecting plug of the harness.
arty4444
Postby arty4444 » Thu Jun 08, 2017 12:40 pm
thanks but It's not at the connector.
