Hello all I am looking for a VW 1.8t AC compressor fitting. Its off a 2004 passat. I needed to make lines from the VW to 2001 dodge dakota. swap info can be found here. http://forums.tdiclub.com/showthread.php?t=465373
As you can see the suction side is an oddball large fitting. I tied to have a local shop cut and braze or weld the line so it could be swedged but the VW pipe is a strange alloy. Any help would be appreciated.
Sanden VW compressor fitting?
