07 Chevy HHR Low Side Service Port
Posted: Sun Mar 19, 2017 9:18 am
by coolperk
I have a leak at the low side service port. I have tried valve cores from 3 different sources. I tried tightening the valve core to spec, under tightening, over tightening, still leaks. Core appears centered, not cross threaded or anything. The port is part of the hose-line. Is there any tricks or tips I can try before I replace the hose-line. I have the tool to change the core without losing refrigerant but after 2 weeks it's all leaked out. Thanks for any tips.
Re: 07 Chevy HHR Low Side Service Port
Posted: Tue Mar 21, 2017 1:59 am
by Dougflas
The valve core is actually the secondary seal. The cap is the primary seal. Are your caps in place? do they have a rubber seal in them?
Posted: Wed Mar 22, 2017 8:16 pm
by coolperk
Yes, I've replaced the cap and it came with an 0-ring. The caps are made of plastic like most cars. My leak detector shows a leak on the low side port. The high side shows no leak.
Posted: Thu Mar 23, 2017 5:30 am
by GM Tech
Does it show the leak with the cap on? To test my leak detector- I take the cap off.
Posted: Sat Apr 15, 2017 4:25 am
by DarrylS
I like to use a product called NYLOG whenever I install any AC O-rings / schrader valves / service port seals or other parts. The stuff is amazing GIT U SUM I keep both red and blue on hand. The red is for R134A and R410 types systems and the blue is typically used for the older R22 and R12
