07 Chevy HHR Low Side Service Port
coolperk
Post by coolperk »
I have a leak at the low side service port. I have tried valve cores from 3 different sources. I tried tightening the valve core to spec, under tightening, over tightening, still leaks. Core appears centered, not cross threaded or anything. The port is part of the hose-line. Is there any tricks or tips I can try before I replace the hose-line. I have the tool to change the core without losing refrigerant but after 2 weeks it's all leaked out. Thanks for any tips.
Dougflas
Re: 07 Chevy HHR Low Side Service Port
Post by Dougflas »
The valve core is actually the secondary seal. The cap is the primary seal. Are your caps in place? do they have a rubber seal in them?
coolperk
Post by coolperk »
Yes, I've replaced the cap and it came with an 0-ring. The caps are made of plastic like most cars. My leak detector shows a leak on the low side port. The high side shows no leak.
GM Tech
Post by GM Tech »
Does it show the leak with the cap on? To test my leak detector- I take the cap off.
DarrylS
Post by DarrylS »
I like to use a product called NYLOG whenever I install any AC O-rings / schrader valves / service port seals or other parts. The stuff is amazing GIT U SUM I keep both red and blue on hand. The red is for R134A and R410 types systems and the blue is typically used for the older R22 and R12
