Adding/draining oil from a Ford FS10 compressor
Posted: Thu Feb 23, 2017 11:36 am
by mcconnell
I guess the subject line says it all. How do I add/drain oil from a Ford FS10 compressor. There is no plugged port on the case.
Thank you
Re: Adding/draining oil from a Ford FS10 compressor
Posted: Thu Feb 23, 2017 8:02 pm
by Dougflas
To drain it, remove it from vehicle and turn it up side down. You should rotate the shaft by hand also. To fill it, pour oil into suction port and also turn shaft.
