CLuch cycling
waho on Sat September 05, 2015 3:49 PM User is offline
Year: 02
Make: chevy
Model: blazer
Engine Size: 4.3
What would be the most likely cause for the compressor to cycle every 10 sec?
emsvitil on Sat September 05, 2015 6:45 PM User is offlineView users profile
low refrigerant
Ed
SoCal
waho on Fri September 11, 2015 3:09 PM User is offline
Static pressure at 90deg outside temp is at 150 on the high side and the gauge is pegged on the low side, does that mean the expansion valve is clogged?
waho on Fri September 11, 2015 3:11 PM User is offline
Meant orifice tube.
mk378 on Fri September 11, 2015 3:25 PM User is offline
Static pressure should be at the condensation point for the refrigerant at ambient temperature. Abnormally high static pressure indicates contamination with air-- likely the system was worked on and the air in the lines was not pumped out before charging.
