Vac'ing lo and hi sides
rstarr on Fri August 08, 2014 6:19 PM User is offline
quick q, is it std to vac the AC system with hi and lo ports open on manifold? i ask because i see several u tube videos showing it this way, i dont see issue for AC system itself, but what about the hi side gauge on manifold, they typically have a needle stop at zero psi.
TRB on Fri August 08, 2014 6:23 PM User is offlineView users profile
Pulling a vacuum with both side open is fine. Only charge thought the low side unless you have a charging station.
rstarr on Fri August 08, 2014 6:36 PM User is offline
what about the gauge though, the low side allows vacuum (by way of allowable needle movement), the hi side doesnt.
wptski on Fri August 08, 2014 10:13 PM User is offline
They are designed to take negative or below zero movement.
