Tech Tip
TRB on Thu September 17, 2009 11:05 AM User is offlineView users profile
A/C systems can be contaminated with metal particles from the normal wear of the compressor and tiny amounts of water moisture. Contamination can cause a system to fail. Protection against contamination is provided by the filter screen on the Expansion Tube and the desiccant in the bottom of the dryer or accumulator. Other forms of contamination may be the wrong kind of oil, wrong kind of liquid charge or other material that will interfere with the cooling system. Almost 100% of moisture is normally removed from the system when it is evacuated prior to installing (R12 or R134a), but flushing the entire system will be the only way to remove any particles.
