Auto A/C Tip 17
TRB on Thu November 13, 2008 9:46 AM User is offlineView users profile
If pressure readings were diagnosed to require adjustment, then most likely it was determined that some loss of refrigerant has occurred. So depending on the amount that needs to be added, how sever is the problem? Was it a very small amount that could be called normal permeation or a larger amount indicative that a repair is required? In either case the correct thing to do is to carefully go over the system and fix any leak that can be identified. It is only going to get worse. Fix any leak that can be identified.
