Auto A/C Tip 10
TRB on Tue May 16, 2006 2:37 PM User is offlineView users profile
When either installing a new a/c system or doing a service job always make the drier the last component replaced before evacuation and recharge. The desiccant in the drier absorbs moisture and will decrease performance and create a problem to the system at a later date. Moisture and refrigerant when combined creates an acid and will damage the internal parts of the a/c system.
Summer Checkup, what can you do?
There are different types of checks that can be done on the ac. Most checks include the following. Visual inspection of the compressor and lines for signs of A/C oil leakage, noise inspection, belt inspection, testing the low and high side pressures for the proper amount of refrigerant, A/C output vent temperature test, inspecting and cleaning drain tube, inspection and confirmation of proper fan operation.
Edited: Tue November 28, 2006 at 4:38 PM by TRB
