Can I check press. on HI side
RonG on Sat March 05, 2016 1:48 PM User is offline
When I ADD refrigerant when the system is low, I connect it and fill to the LOW side. Therefore I cannot connect the LOW gauge to determine when the system is correctly charged. Can I use the HIGH side pressure to determine when the system is fully charged? reply to [email protected]
GM Tech on Sat March 05, 2016 2:37 PM User is offline
No, Use a scale and charge to specified weight- and charge from a vacuum to assure proper weighed in charge. The required amount is on your under hood label. I would never advise charging a mobile unit by low or high side pressures- too many variables. And if this is a chronic problem- I would fix the leak before adding refrigerant.
