how many cylinders in this 434 harrison compressor
hw3tnt on Thu September 03, 2015 11:23 PM User is offline
Year: 1986
Make: harrison
Model: 1131434
Engine Size: 350
Refrigerant Type: R12
Ambient Temp: ?
Pressure Low: ?
Pressure High: ?
I have a Harrison 434 mod. 1131434 compressor on my 86 Chevy C-10 Scottsdale pickup truck 350 gas engine with carb.. I am planning on flushing my AC system and cleaning all of the components. I hope yall can tell me how many cylinders are in this compressor and how to drain the oil out of it. I don't know how much oil is in system now and will put a new dryer in and flush the rest. How can I get oil out of compressor while its in truck if possible? Compressor info sticker says system needs 6 oz of oil. Thanks for your time. HIII
GM Tech on Fri September 04, 2015 8:07 AM User is offline
R-4 Compressor has four cylinders 90 deg apart running off of a scotch yoke design- No way to drain oil while still mounted to engine. I hope whatever flush you use, you are able to get it all out, I personally do not flush with solvents for this very reason- have seen the damage residual solvent (degreasers) do to a compressor that needs fresh clean lubricant.
HECAT on Fri September 04, 2015 11:20 AM User is offline
To drain the R-4, take it off, ports on back in down position over catch pan, rotate, rotate, let sit overnight, rotate, rotate. Take the OT out and remove the accumulator. Flush the evap and condenser separately. Flush properly, blow-blow-blow to dry well, then dry some more. The wrong flushing solvents, wrong methods, poor drying, and shortcuts; do cause problems.
hw3tnt on Sat September 05, 2015 7:22 PM User is offline
Thanks I'll try that Monday. HIII
