2010 Camry LE
nedzad1 on Mon August 31, 2015 1:46 PM User is offline
Year: 2010
Make: toyota
Model: camry
Engine Size: 4cyl
Refrigerant Type: 134A
Ambient Temp: 95
Pressure Low: 75
Pressure High: 150
I have problem with 2010 Camry LE. It blows warm air, the outside temperature is 95 F, and low pressure is constantly 75 PSI, high side is 150 PSI. The pressure is constant, both fans are on and compressor is getting 12V. Do I have weak compressor or maybe bad expansion valve?
Cussboy on Mon August 31, 2015 2:26 PM User is offline
So the compressor engages? That means the center section clicks and pulls in and turns when the AC is switched on (not just the outside pulley turning).
nedzad1 on Mon August 31, 2015 2:34 PM User is offline
it has internal clutch. It pulls down from static pressure so I believe compressor clutch work.
nedzad1 on Fri September 11, 2015 10:08 AM User is offline
The problem fixed, it was Electronic refrigerant control valve on the compressor that needed to be replaced.
