Denso 10S17F coil needed
slow on Mon July 13, 2015 8:21 PM User is offline
Year: 2006
Make: Chevrolet
Model: Express 3500
Engine Size: 6.6L
Refrigerant Type: r134a
Ambient Temp: 100
Pressure Low: n/a
Pressure High: n/a
Does anybody know where to get just a coil for this compressor:
Part numbers are:
5277426
MC 447170-6199
10S17F ND-OIL 8230cm2
Denso
On the clutch sticker.
I accidently reversed the polarity and burned out the coil, I hate to replace the compressor for just a coil swap. I feel comfortable doing a clutch swap if necessary. I just hate to pay for more parts than I need. Does anybody know how the denso part numbers work, does a coil for a 10S17 work?
This is in a very low mile engine swap vehicle, so I hate to replace the compressor if not necessary. This has the 6.6L Duramax engine.
Ryan
emsvitil on Tue July 14, 2015 6:41 AM User is offlineView users profile
The coil is probably still good.
Probably just burnt out the flyback diode.
Ed
SoCal
GM Tech on Tue July 14, 2015 7:44 AM User is offline
Get one off of a core from your local Stealership- they will probably give it to you for the $15 core charge.
slow on Tue July 14, 2015 8:00 AM User is offline
I will try the core route, unfortunately I do not have any good connections at the local dealers, but it cannot hurt to ask.
I am getting 0.02 ohms of resistance when measured either direction.
Ryan
TRB on Tue July 14, 2015 12:44 PM User is offlineView users profile
H20-7302
