relative Humidity question
bll230 on Sat June 27, 2015 4:09 PM User is offline
Question for a AC expert. I have recently moved from Georgia at 90% humidity or so, to Las Vegas, at 0% humidity. We have 3 cars, 96 Integra, 03 C class MB, and new Subaru, all of which I have the service manuals for.
The AC chapter for all three cars specifies that the gauge readings should be done with the humidity between 30-80%. What do AC shops do out here in the desert to determine the proper pressures? Do I use the 30% humidity value and not worry about it, or do I extrapolate the values to 0% humidity?
On the east coast touching the return line and looking at the condensation on it was a bit of a backup confirmation that my pressures were correct. Here in Vegas there is no condensation and consequently the return line doesn't feel as cold.
John
GM Tech on Sat June 27, 2015 6:50 PM User is offline
They measure refrigerant charge by weight and put in the underhood specified amount..
bll230 on Sat June 27, 2015 7:42 PM User is offline
I figured that is what they do for an initial fill, but what about servicing an existing fill?
John
GM Tech on Sat June 27, 2015 11:01 PM User is offline
we reclaim all that is in the system then evacuate, then re-fill to underhood spec. Anyone who specializes in a/c has a recovery/refill machine--otherwise you are dealing with unexperienced a/c mechanics.
