Low Side-high reading / High Side-low reading
ykf7b0 on Fri June 19, 2015 12:01 AM User is offline
Year: 1976
Make: Chevrolet
Model: Corvette
Engine Size: 350
Ambient Temp: 90
Pressure Low: 80
Pressure High: 80
I'm trying to get the a/c up and going on my wife's 76 Corvette. The system has been converted to R134a. I have replaced evaporator, new desiccant, total flush, and lengthy vacuum and leak check. The A6 compressor clutch is engaging but the pressure has equalized with a low high side reading of 80 and a high low side reading of 80. Has my compressor gave up?
TRB on Fri June 19, 2015 11:12 AM User is offlineView users profile
With compressor engaged and equal pressure. It is a good chance your compressor is not working correctly if fully charged.
ykf7b0 on Fri June 19, 2015 3:24 PM User is offline
I don't have it fully charged. I couldn't get any more refrigerant to draw in other than 16 oz. What's going on with it? Thanks!
GM Tech on Fri June 19, 2015 3:40 PM User is offline
Did you close your valves on your gage set when taking the readings? Otherwise you are bypassing the system and pumping thru your gage.
ykf7b0 on Fri June 19, 2015 7:55 PM User is offline
I don't think I understand you correctly. I have the low pressure guage valve open when charging and high pressure gauge valve closed. I have the coupler valves open on both high and low charging ports. My readings are obtained through this proceedure. Please explain. Thanks!!!
Jag987 on Sat June 20, 2015 3:25 AM User is offline
If the couplers that attach to the car at the ends of the hoses have manual valves on them, they need to be open. The knobs/valves on the manifold next to the gauges need to be closed.
ykf7b0 on Sat June 20, 2015 10:16 AM User is offline
Both manual couplers are open and Low side gauge valve is open to ingest refrigerant - correct? To get readings both Low and High side manifold gauges are closed - correct? If so, my pressure readings are always end up equal (80 psi) on both gauges and I cannot get the compressor to draw in any more refrigerant than the 16 ounces that it has taken in. Compressor clutch is engaged.
Crude dude on Sun June 21, 2015 4:51 AM User is offline
Wonder if there is an issue with the orifice tube or expansion valve. Sounds like no flow control.
ykf7b0 on Sun June 21, 2015 9:16 AM User is offline
It could be that and I hope it is not. I have a factory VIR.
