dodge ram 2500 hige side connector
ces44 on Fri August 29, 2014 10:18 AM User is offline
Year: 2001
Make: dodge
Model: 2500
Engine Size: 5.8
The high side fitting on this truck had a rubber? ball rather than a schrader valve. When I connected to it, the ball was punctured and would not seal. Do these trucks take a special fitting to connect to them? I'm having to replace the line at my expense. The replacement also has the same type of fitting.
chris142 on Fri August 29, 2014 10:45 PM User is offline
That port is used on many cars and trucks. I replace every one I work on before I connect the hose. The old ones leak......Always
