Clogged Evaporator?
Smitty on Tue August 19, 2014 5:36 AM User is offline
Year: 2001
Make: Lincoln
Model: Continental
Engine Size: V8
I have a 2001 Lincoln Continental which doesn't blow cold. I followed the factory service manual troubleshooting steps and performance tests. According to the factory service manual, it is a clogged evaporator coil. Does this mean internally clogged or externally clogged. Thanks.
HECAT on Tue August 19, 2014 7:14 AM User is offline
I can only guess. Restricted air flow would indicate external clogging (possible). Restricted refrigerant flow would indicate internal clogging (un-likely).
