No front A/C condencer
hooper454 on Fri August 15, 2014 6:51 PM User is offline
Year: 2002
Make: Chevy
Model: c-3500
Engine Size: 5.3
Refrigerant Type: 134
Ambient Temp: 100
Pressure Low: 75
Pressure High: 150
Hello all,
I have a 2002 Chevy van (15 passenger) Dual A/C system, one compressor. Rear unit is a Carrier EM-14 with a CM-2 condenser unit. It arrived at or shop out of Freon because the high pressure switch was blown off the back of the compressor. After installing new switch and recharging, I knew it would need a compressor, 150/75 @ 100 degrees. The thing that baffles me is there is no front condenser in front of the radiator. My question is, Does the rear condenser unit have enough capacity for a dual system, or am I going to replace all necessary components/flush/recharge just to have this problem keep repeating for lack of proper heat exchange?
On a side note. I found this site while searching for parts for this vehicle. Very nice!
Dan
HECAT on Sat August 16, 2014 11:17 AM User is offline
Taking a quick look at the Carrier install data shows that front and rear air can be run with the stock located condenser or the CM-2 unit.
