Dougflas on Sat August 09, 2014 7:06 PM
Originally posted by: mk378The test is to close the valve wheels, so the vacuum pump is no longer connected to the car, and watch if the low side gauge moves up. If it does, there's a leak.
The sight glass in a manifold is a gimmick feature. It has pretty much no practical use. More expensive full-professional manifolds don't have them.
I have to respectfully disagree. The TEST 550 series are professional manifolds and in fact have sight glasses. One of the features of a sight glass is to be able to monitor the liquid refrigerant entering the manifold. NPR makes a sight glass that connects to the third hose at the manifold. Some refrigerants must be charged as liquid and do need a sight glass.
If you think the seal at the sight glass is leaking, close both handwheels and put the third hose to a refrigerant source. Use bubble search at the sight glass to see if there is a leak.
wptski on Sat August 09, 2014 8:08 PM
If you think the seal at the sight glass is leaking, close both handwheels and put the third hose to a refrigerant source. Use bubble search at the sight glass to see if there is a leak.Yes, like R410A that must be charged as a liquid but if you have to charge on the low side while running, you don't want to see liquid or you will slug the compressor therefore you have to throttle it in.
Dougflas on Sat August 09, 2014 10:40 PM
you should be using an expander so you don't slug a compressor
wptski on Sat August 09, 2014 11:03 PM
You mean a liquid to vapor adapter which is just a adapter with a pinhole in it? No need for sight glass then. I have one but so far I've charged my full charge using liquid on the high side with system off after evacuation.
