No cold air in 2002 Grand Am
wearend on Tue May 27, 2014 9:30 PM User is offline
Year: 2002
Make: Pontiac
Model: Grand Am
Engine Size: 2.2
I have no cold air. Compressor spins. Clutch is always engaged when air in turned on. It won't take any freon. I don't have access to gauges to check the pressures right now. Any ideas before I try to find a gauge?
GM Tech on Tue May 27, 2014 10:14 PM User is offline
Number one failure mode is loss of refrigerant due to a leak- highly suspect V-5 compressor case halves= your system is a variable compressor- it will run with as little as 5% of the system charge in it- without cycling
Have the system recovered and refrigerant weighed to confirm loss of refrigerant.
wearend on Wed May 28, 2014 3:54 PM User is offline
Alright. Thank you.
