Source for #12/M27x2mm Aluminum A/C Line
wrenwright on Tue May 27, 2014 10:46 AM User is offlineView users profile
I'm looking for a source for #12 a/c aluminum tubing with an M27x2mm female fitting on both ends. I've found #12 with SAE fittings/threads, but not any metric in this size. I want the tubing that comes in straight lengths that can be bent to shape. I'll probably need a length of around 36"
Does anyone know where this sort of tubing can be sourced?
Thanks!
Dougflas on Tue May 27, 2014 2:45 PM User is offline
if you can't find it, buy the fittings and have the line made up by TIG welding.
wrenwright on Tue May 27, 2014 10:03 PM User is offlineView users profile
I thought about that, but would really like to find an off-the-shelf solution.
I also thought about using aluminum brazing rod to join a M27/#12 fitting to a section of aluminum tubing. I thought if the barbed end of the fitting would sliding into the tubing, it could be brazed together. I would need a source for #12 tubing for this to be an option.
Anyone know where I can get #12-sized tubing?
Edited: Wed May 28, 2014 at 8:13 AM by wrenwright
