Low side in vacuum
rschmitt2 on Mon March 24, 2014 8:02 PM User is offline
Year: 1992
Make: Plymouth
Model: Colt Vista
Engine Size: 1.8
Refrigerant Type: R134
Ambient Temp: 55
Pressure Low: 11 VAC
Pressure High: 65
Last summer, the AC worked just fine, but it was rarely used over the winter with the defrost. When I turned it on the first time this Spring, no cooling. I put gauges on it and when the compressor kicked on, the high side went to 65 and the low side went into vacuum. Last summer I put in a new condenser, new compressor, new evaporator, and new drier. Can't figure out what could have happened over the winter to cause this problem.
GM Tech on Mon March 24, 2014 8:53 PM User is offline
You lost about 80% of your refrigerant over the winter is what went wrong.......check your charge by recovering and weighing to confirm-- then find and fix your leak.
mk378 on Mon March 24, 2014 9:32 PM User is offline
Leave the compressor off until the high and low pressures equalize and then compare that "static pressure" to the saturation pressure at the ambient temperature (this is the only time you read the temperature scale on the gauge instead of the psi scale). If it is lower, that means that no liquid refrigerant remains in the system-- apparently a major leak has occurred like GM Tech said.
