ac electrical problem
santiagj on Sun March 16, 2014 10:29 AM User is offline
Year: 2006
Make: mitsubishi
Model: outlander
Engine Size: 4cyl
Country of Origin: Puerto Rico
I have a problem with the A/C.Depletes the battery once you put the air conditioning fuse have to keep the fuse out from the A / C did not lie to the battery. I can not use the A / C because of this problem. HELP PLEASE!!!
94RX-7 on Sun March 16, 2014 1:18 PM User is offline
Try pulling the compressor relay instead of the fuse. The relay may be stuck in the closed position and always sending power to the compressor clutch.
mk378 on Sun March 16, 2014 4:02 PM User is offline
There is usually another relay of the same type in the same box which controls something you're not using at the moment, like the rear defroster or the fog lights. Substitute that relay for the A/C one and see if the problem goes away.
Edited: Sun March 16, 2014 at 4:16 PM by mk378
