High side fitting on hose too large
joeld on Thu August 01, 2013 2:07 PM User is offlineView users profile
Year: 1989
Make: Chev
Model: Corvette
Engine Size: 350
Refrigerant Type: R12
I just received my manifold gauge set: Mastercool #98661-Pro. The high side hose fitting is too large for the vehicle fitting. Any ideas on what to do with this?
Joel
HECAT on Thu August 01, 2013 2:37 PM User is offline
If you are trying to connect the (R-12) 1/4 flare and it is too large, then you have a 3/16 flare and will need an adapter.
joeld on Thu August 01, 2013 3:35 PM User is offlineView users profile
Yes, that is what I have. Any suggestions on the adaptor?
Joel
TRB on Thu August 01, 2013 4:18 PM User is offlineView users profile
Sounds like you need the 3/16th adapter.
joeld on Thu August 01, 2013 4:55 PM User is offlineView users profile
Is this what I need? #90358
Joel
hhttp://www.ackits.com/merchant.mvc?Screen=PROD&Store_Code=01&Product_Code=90358&Category_Code=ttp://www.ackits.com/merchant.mvc?Screen=PROD&Store_Code=01&Product_Code=90358&Category_Code=
Edited: Thu August 01, 2013 at 8:37 PM by joeld
joeld on Thu August 01, 2013 8:45 PM User is offlineView users profile
Let me try this again. I've tried to link the info on the adaptor, but can't seem to get to work.
The adaptor info says "R12 High Side Adapter 1/4" X 3/16 FFL.
Part # 90358
Can anyone tell me if this is what I need in order to connect my high side hose to the high side fitting.
Joel
wptski on Fri August 02, 2013 9:52 AM User is offline
Yes, that's the correct adapter.
mk378 on Fri August 02, 2013 10:31 AM User is offline
Very late in the R-12 era, GM cars (probably not your 1989) require the "GM deep throat" adapter. If the valve pin is nearly flush with the top of the flare like it is on the low side, use the regular adapter. If the valve is recessed in the port you need the deep throat adapter.
joeld on Fri August 02, 2013 10:57 AM User is offlineView users profile
Thank you guys very much for the replies and help.
Joel
