Year: 2003
Make: chevy
Model: s10
Engine Size: 4.3
CAN ANYBODY TELL ME WHERE THE evaporator DRAIN IS I WENT TO A GM DEALER AND THEY DIDN'T KNOW I WENT ON LINE TO SEARCH AND CAN NOT FIND ANYTHING ABOUT WHERE IT IS ether I LOOKED ALL OVER IT AND CAN'T FIND IT MY AC NEVER SEAMS TO DRAIN ANY WATER OUT ???? THANKS,JOHN
it is embedded underevap case housing-- does your truck cool? will only drain under humid conditions....
YES COOLS GREAT I HERE WATER SOUND IN THE evaporator BOX SO I THOUGHT IT WAS NOT DRAINING EVEN ON HIGH humidity DAYS.. THANKS,JOHN
Find the drain hole and take a long plastic zip tie and poke it in the drain hole a few times to loosen up any leaves, sediment etc. and the case will drain out.
The drain is more like a slot as I recall..
THANKS GUYS I FOUND IT IT IS almost TO THE FIRE WALL ON THE EVAP BOX BUT I THINK IT DOES NOT SEAM TO DRAIN A LOT IS because IT IS NEXT TO THE exhaust manifold AND GETS VERY HOT SO I THINK IT evaporates VERY quickly.. THANKS AGAIN,JOHN
