GM V5 - can't charge it - Low pressure=90PSI High pressure 95PSI
GKN on Sun July 07, 2013 5:57 PM User is offline
Year: 1997
Make: Pontiac
Model: Firebird
Engine Size: 3.8
Ambient Temp: 85F
Pressure Low: 90
Pressure High: 95
I am having problem charging the system. I did pull vacuum for 20min and I tried to charge it, but the system takes very little refrigerant (about 6oz). The pressure for Low and High side is about the same - 95psi. The compressor comes on - but the Low and High pressures stay the same. Do I have bad compressor or bad control valve?
I decided the recharge the system because I had similar condition – Low and High pressure were staying at 100psi.
GM Tech on Sun July 07, 2013 8:05 PM User is offline
As long as you are sure you have the gage set valves closed (at least the high side) when charging- then you have a bad control valve- if both valves are open- you have an external bypass going on through the gage set......
GKN on Sun July 07, 2013 10:07 PM User is offline
Thank you!! Ordering control valve right away after I figure out the color coding
