04 Dodge pickup, no cool
bfox on Sun June 23, 2013 10:04 PM User is offlineView users profile
Year: 2004
Make: Dodge
Model: pickup
Engine Size: 4.7
Refrigerant Type: R-134A
Ambient Temp: 90°
Pressure Low: 50-60psi
Pressure High: 150psi
2004 Dakota no cool.
Engine RPM at 1500 during checks.
denso 10s17e compressor.
Truck is less than 10 years old and has a rebuilt compressor on it. Obviously something happened.
Lots of trash in the lines when I opened it up but the orifice wasn't totally plugged. Should be doing some cooling.
Pressures would seem to indicate compressor not pushing anything. Covered front of condenser. Pressure did not change.
The folks are still trying to decide whether they can afford to repair the truck.
I have a 2000 Durango doing the same thing. Sanden compressor.
Showing the same pressures. Changed the compressor on it and didn't change a thing. Also put a new oem expansion valve and dryer.
I need some advice on this problem.
God Bless America.
mk378 on Mon June 24, 2013 11:10 AM User is offline
Trash in the lines means the compressor is shot, where else would it have come from? Total system replacement is not off the table. If the shop has a good flushing machine you may be able to reuse the evaporator, but replace everything else.
