Refrigerant leaks 1996 Lumina 3.1L
WyrTwister on Sat May 18, 2013 10:53 PM User is offlineView users profile
Year: 1996
Make: Chevy
Model: Lumina 4 door sedan
Engine Size: 3.1L
Ambient Temp: 95
Pressure Low: 35
Well , latest charge of 134a leaked down , earlier in the week . Could not find any leaking hoses or lined . But where the 2 hoses bolt to the compressor ? All of the underside of the engine and the compressor is encrusted with oil and dirt . So , I could not tell if anything was leaking at the hose / compressor interface .
Also , pretty much the same thing , could not tell if it was leaking at the compressor shaft seal , either . ( I had introduced red dye / oil mix to the system last time I charged it with refrigerant . )
So , I pulled the compressor clutch and the shaft seal area was wet with dirty brown oil . No evidence of red die , but I decided to replace the seal .
Last time . I bought a seal kit from O'Reilly Auto Parts , for the 91 Caprice . They seem to no longer carrier it . Same with Advanced . Auto zone seemed to show it in the computer , but would have to order it . I wanted to get the car put back together today .
Praise the Lord . NAPA had the Seal kit , but it was more $$$ than what I had paid for the previous one at O'Reilly's . Such is life .
Got it all put back together and vacuumed it down . Seemed to hold a vacuum , so I put 2 cans of 134a in the system . Do not think that is quite enough , but I could not remember the proper amount and was too tired to figure it out / look it up .
Discharge air at a fast idle was a hair below 50 degrees F . If it does not leak out , I will add more .
God bless
Wyr
GM Tech on Sun May 19, 2013 9:18 AM User is offline
Compressor belly leakers are common on your V-5 compressor- as well as shaft seals.
WyrTwister on Sun May 19, 2013 8:49 PM User is offlineView users profile
Are you saying leaks in the body of the compressor ?
Does it use gaskets or o-rings ?
Thanks , :-)
Wyr
God bless
GM Tech on Sun May 19, 2013 10:21 PM User is offline
O-rings- corrosion crawls under them...
