Elevation
WyrTwister on Thu May 16, 2013 9:08 PM User is offlineView users profile
My vacuum pump was only pulling 22" of vacuum , on the Caprice . I looked the hose from the low pressure port of the gauge set , to the high pressure port & turned the pump on .
This setup should yield a reading of the max vacuum the pump can pull ? Still 22" .
Now , I can not say the pump or the gauge is the best in the world ?
But I am at an elevation of ~ 3,250 feet . So , how much vacuum should good equipment pull at this elevation ?
God bless
Wyr
HECAT on Fri May 17, 2013 12:16 PM User is offline
this may help.
WyrTwister on Sat May 18, 2013 2:55 PM User is offlineView users profile
Thank you , :-)
God bless
Wyr
WyrTwister on Sat May 18, 2013 2:56 PM User is offlineView users profile
Edited: Sat May 18, 2013 at 2:56 PM by WyrTwister
