Valve core
awc on Thu May 16, 2013 4:27 PM User is offline
Year: 97
Make: Ford
Model: Ranger
Engine Size: 4.0
Refrigerant Type: 134
Need to replace the valve core on the low side. The port is on the Accumulator. I think the core is the JRA but not sure.
WyrTwister on Thu May 16, 2013 4:43 PM User is offlineView users profile
I picked up a repair kit at O'Reilly Auto Parts , that has 2 - 3 Shrader valves , w removal tool and high & low pressure service port cap .
$ 5 - $ 10 , IIRC .
God bless
Wyr
awc on Thu May 16, 2013 5:35 PM User is offline
I seen that kit. Not sure if it has the right size core though.
If it helps It uses the Large bore end on my core tool. The service cap is 9mm.
WyrTwister on Thu May 16, 2013 9:00 PM User is offlineView users profile
On my 1991 Caprice 5.0L , the tool that came with the kit fits the shrader valve in the low side port on the new accumulator .
The " top " of the shrader valve , in the high side port is larger than the hole in the end of the tool & will not fit .
Open to suggestions for a tool that will fit the high side shrader valve ?
God bless
Wyr
awc on Fri May 17, 2013 1:40 PM User is offline
Sounds like you need a large bore valve tool. I think the part number is Mastercool 81290 or 91290 can't remember.
NickD on Sat May 18, 2013 6:11 AM User is offline
What valve core on a 97 anything that came with a quick coupler neoprene disk that never seems to seat properly. Scharder valve cores were once a luxury taken away.
Cheapest thing you can do is to try to find a decent new cap, put a couple of drops of Nylog in it and pray it doesn't leak. These EPA changes that are suppose to prevent leakage are unbelievable. Or just change the entire valve assembly that may also require replacing the line with it.
awc on Sun May 19, 2013 7:50 AM User is offline
Nick, It does actually have a Schrader valve not the little black button in the port. I tried tightening it up but it wasn't loose.
