Relocating compressor plug
blackcat on Wed May 15, 2013 7:38 AM User is offline
Year: 1970
Make: chevrolet
Model: el camino
Engine Size: 396
Refrigerant Type: a6
I just installed a big block in my 1970 el Camino(had 350) and I am using some 71 brackets but my question is the location of the plug which is in the wrong location. If I remove the clutch is the plug part of the assembly and can I then locate it in the proper position?
The plug is jammed up against the bracket:
Should look like this:
Thanks.
GM Tech on Wed May 15, 2013 9:08 AM User is offline
Remove the clutch, then the pulley, then the coil-- all are 3 separate items- then rotate the coil to desired position and re-install- clutch and pulley are press fits- need special tools unless you are creative-- there are tool kits out there...to be bought or borrowed.
blackcat on Wed May 15, 2013 9:18 AM User is offline
Thanks. Do you think Autozone,etc. will have the tools?
