O-Ring not sealing
lehyumaz on Fri October 05, 2012 12:10 PM User is offline
Year: 1998
Make: Mitsubishi
Model: Galant
Engine Size: 2.4
Refrigerant Type: R-134A
Ambient Temp: 100
Pressure Low: 40
Pressure High: 200
O-ring at evaporator to suction hose will hold a vacuum but leaks under pressure. Possible cause(s)?
Yuma AZ.
lee henderson
mk378 on Fri October 05, 2012 2:18 PM User is offline
Wrong size o-ring, o-ring damaged during installation, or metal parts damaged or corroded.
GM Tech on Fri October 05, 2012 4:21 PM User is offline
wrong size o-ring- obviously moves and does not compress..need at least 12-19% compression in a joint for a good o-ring seal. Try a bigger cross-sectioned one.
lehyumaz on Fri October 05, 2012 6:45 PM User is offline
Thank you MK and GM. Just tried larger O-ring with same effect. Will try to locate and install new suction hose, then evaporator if required. will reply when complete.
lee henderson
