Adding oil to an A6 Compressor
whizzer on Sat September 29, 2012 7:47 PM User is offline
Year: 1971
Make: Chevy
Model: Corevette
Engine Size: 454
Refrigerant Type: R134
Ambient Temp: 75
Hi All,
Where do you add oil on an A6 compressor? The sump drain plug or the inlet hole? Does it matter? Is the sump separated from the rest of the system? I added 10OZ to the inlet and while it all went in when the compressor was on the bench, when I installed it, oil poured out and made a mess everywhere. I tried to keeping the inlets as high as possible.
If I add oil through the sump drain hole, will it be less prone to pouring out during install?
Can I add less to the compressor, say 6OZ, and add the remaining oil to the dryer and/or condenser? I've read other posts suggesting that, more or less.
Thanks.
TRB on Sat September 29, 2012 8:41 PM User is offlineView users profile
Oil in the suction port. Use the plate that cover the ports so oil does not drain out while installing. On this model I would place the entire amount of oil in the compressor.
whizzer on Sat September 29, 2012 9:02 PM User is offline
Thanks for the response. You mean a plate that would come with a new or reman one? I don't have one of those. I guess I could check with the local parts store.
