Year: 1999
Make: Chevy
Model: Tahoe
Engine Size: 350
Refrigerant Type: 134
Ambient Temp: 95
Pressure Low: 55
Pressure High: 225
Hey guys, my a/c compressor is disengaging too often and when i took off the plastic caps to attach the gauges, the high pressure port started to shoot off alot of air or freon. Should this happen when just removing the cap or is the port bad? It was also covered in black oil.
I added 24oz of 134 and the gauges read 50 and 215psi. The air blew cold for a while but then blew hot for about 5 minutes. How can i tell if im low on freon?
Feel the inlet and outlet at the evaporator if its an accumulator type system with engine running and A/C on ( where the tubing goes in from a tall usually black or silver canister at the firewall near the blower motor). Both should be cold and about the same temperature.
The suction line from there all the way to the compressor should be cool too if it has a full charge.
The other line ( discharge) will be hot.
Just another brick in the wall
Had a little mule I fed him castor oil and every time he jumped the fence he fertilized the soil
If it gets cold once, you have enough-- unless it is leaking out as fast as you put it in. Does the compressor still engage when it is blowing hot?
